How do I check if my laptop can receive 5Ghz router signal?
BeetleDad
rich912
Hi BeetleDad,
Open Vaio Control Center > Network Connections > Vaio Smart Network > Advanced > Settings.
Here you will find the ‘Mode’ options under the drop down menu.
The instructions may vary slightly for your model but the principal will be the same.
Rich
Go n-éirí an bóthar leat
rich912
Hi BeetleDad,
Rich
