How do I disable the touchpad?
Termite05
I would like to disable the touchpad since it interferes with my typing. How do I do this?
5 REPLIES 5
rich912
Hi Termite05 and welcome to the forum.
This depends on your model but click Start > All Programs and open Sony Notebook Setup or Sony Notebook Control (or something similar) > on the touchpad tab select ‘disable touchpad’.
Go n-éirí an bóthar leat
Thalamus.
Champion
Hi Termite05
Welcome to Club Vaio..:smileyhappy:
In the mouse properties (found in Start > Control Panel > Printers and Other Hardware > Mouse) you may have an option to turn off the touchpad whilst typing and also increase the delay after the last key is pressed...
jumpsuit
"How do I disable the touchpad?"
Break its legs.
seedkeeper
none of the solutions presented work for me, I have a FE series with winXP
rich912
Hi seedkeeper,
Do you have Sony Notebook Control/Setup listed in Start > All Programs – If so is there a Touchpad tab?
If not have a look in Device Manager under Mice and other pointing devices – do you have a PS/2 pointing device listed or a PS/2 mouse? If a PS/2 mouse then you need to update the driver – come back for further instructions on this.
