how to changing my recovery language
muthanna
hi
I buy a vgn-n38z vaio notebook from Nederland, the first installation is done with dutch language.i try to make a complete recovery for my labtop but it still in dutch language.I heard about these 2 files version.ini and version.txt that are found in the recovery partition and when i change the contians for these files , it will sucess to change the recovery language. my question is that ok or it's just suggestions and if any one know a way to change the vista premuim language from dutch english in my recovery that will be a good help to me , muthanna.hasan@yahoo.com
4 REPLIES 4
profile.country.pt_PT.title
V57...
Hi muthanna,
You can't...only with the Windows Vista Ultimate...
V57...
Upgrade to Vista Ultimate which allows for the installation of a Language Pack in another language.
muthanna
thank you fpr your help
yes i search about this prolems and i discover same like your solution
regards
V57...
You're welcome muthanna.
