how to check how long the guarantee is valid for my laptop
profile.country.bg_BG.title
Lilinkaaaa
how to check how long the guarantee is valid for my laptop?
Hi Lilinkaaa and welcome.
Was your Vaio bought in Europe and is it a European model?  If you have a US model, then there are complications.  Which model do you have?  Is it registered with Vaio Support?
The usual warranty in Europe is 2 years from the date of purchase. (This is different if purchased in the UK or Ireland).
Have a look here: -
http://www.sony.bg/hub/vaio-services
:thinking:
Have a look here: -
:thinking:
