Suprise Suprise to hear that my new SZ4 series that I got yesterday had junk installed with the Vista restore pack.
Not happy once again although the amount of junk was less than my SZ2 series.
Anyway... Not wanting all that rubbish trialware... I decideded to format the machine.
Obviously doing it via the restore pack will only put the rubbish back... so I used the rumours that have been going around.
"basically... all flavours of Vista are on ONE DVD (32bit flavours on one, 64 on another)... it is the Serial Number that determines WHAT is installed".
Not sure on legality just like my XP clean post but I borrowed a Vista Home Premium Retail CD from work and made a copy.
On installing this, once the serial number screen popped up, I entered the OEM serial number of my laptop (the sticker under the laptop)
Suprisingly, it worked!
It went onto install the rest of the way.
Only issue was activation whereby it would not automatically activate online. But having called the MS activation centre, it went through flawlessly.
I am unsure if this was because of the different media used - although I doubt it.
Lastly... prior to formatting, on clicking the VAIO restore Utility... you can create "vaio support folders". This creates a VAIO folder that has the following:-
Applications
Drivers
Hotfix
Hotfix is empty but all the essentials such as battery checker, fingerprint software, bluetooth and so on, is under the applications
The drivers is obvious - all drivers for your laptop and most had both XP and Vista enabled drivers.
Infact, the whole process took less than an hour from the install to having it up and running with all apps and drivers installed thanks to Vista being able to search for drivers within subfolders... all you do is set the folder to c:\vaio\drivers and each time you search for the hardware - it finds it!
Most drivers however were already installed - including, wifi, network, graphics, sound
Hope this helps.
Bottom line is, you CAN still get rid of the junk in a clean fashion.
Thanks guys, I will do that.
Hey Akash
I have a question regarding your instructions for the installation. Could you further explain how you activated vista (something about calling ms)? Did u actually call? Please explain.
Thanks.
Hey Akash
Thanks.
Yes, as long as your hardware remains (almost) the same, your request code doesn't change.
It worked a treat. Took about 2 hours to swap the 4200rpm hard drive of my FE41Z with a 5400 one, install vista (twice) from the upgrade DVD and the driver software. Got a lovely clean install and a vista performance index of 4.5 (the hard disc score jumped from 4.2 to 4.8).
Thanks for the tips chaps.
Hi guys,
Install worked like a charm. Had to activate via phone though. Now all that needs to be done is to install all my software (no more sony junkware :smileygrin: ) and then the job is done. Thanks for all your help.
Akash, as for the score vista gave to your system. Mine system got a score 4.2 (fe41s). This is based on the lowest performing hardware element of your pc (hard drive in my case). My configuration is a little different your SZ
Here are a few specs: T5500, 160GB 4200rpm, 2GB 667MHz DDR2 and Go7600 GPU. The score you receive of vista is based on these elements. The difference between mine config and Bonce is the processor (and now hard drive). Did you receive this score after the clean install or before? I think the 3.3 should then be based on the GPU because there is big performance difference between 7400 and 7600. But this will only affect you if your a gamer.
By the way Bonce, is it difficult to swap the drive to a 5400rpm? I know that sony drive replacements are real hassle. Is the drive located adjacent to the touchpad?
Hi guys,
