Solved! Go to Solution.
No, this is not possible to make Windows 7 Recovery Discs that will work on your FZ21Z.
Recovery Discs are Model Specific and you cannot use another Vaio. The Recovery Discs for your model are Vista 32-bit and are an exact copy of the original Recovery Partition including model specific information and drivers/software. The original Recovery Partition was an EISA Configured Hidden Partiton.
If you want to make recovery software for Windows 7, you will need to take a mirror of your installation using something like Acronis True Image - this can also be made bootable.
Alternatively, you could purchase a set of Recovery Discs for your FZ21Z from Vaio Support - but these will be VISTA 32-bit.
