Hi!
I want to downgrade my FZ38M to XP pro, but need sata drivers at the start of winxp installation, what to do ?
Regards
Jonas
Hey there!
You can install Windows Xp on your Vaio by using a slipstream cd. That means you have to include your s-ata drivers in a Xp installation disc. More information can be found over the Internet.
Have fun and before doing this make sure you'll be able to install your hardware under Xp, otherwise this will be a waste of time.
