How to get back the factory settings?
kamalkpaleti
Hi all...
I have purchased VAIO (VGN-NS30E) one year ago.I did not prepare recovery disks.Unfortunately my hard disk failed and I replaced it with a new one.Now how can I get back my vaio pre-installed softwares and factory settings? some one please tell me.
Thanks in advance...
Regards,
Kamal K.Paleti
4 REPLIES 4
peshyxp
Only way is to buy the recovery discs from Sony who will charge you around £44 or if you can find someone with exactly the same model and ask them to burn you a set that will do the trick
Give me a shout if you dont have any luck finding anyone since i may be able to assist
kamalkpaleti
Thank you peshyxp....
Actually,none of my friends have the same model. Please tell me where can I buy those recovery disks.I will be very happy if you assist me....Thank you once again.
peshyxp
Drop me a message w ur contact details and will gladly assist
kamalkpaleti
Hi...Thank  you for your reply.
Actually I live in India.My brother is in Luton(London).
If you have the recovery disks (Model : VGN-NS 30E/S), please contact me. Then,he will contact you.
Message was edited by: -frank-
