I lost the sound on my Vaio VGN-N19VP after having (badly ...) uninstalled components. The "Fn+Sound Off/On", "Fn+Sound higher" and "Fn+Sound lower" doesn't work any more. I don't have the sound any more. Do you know how to make it work again ?
Seb
Hi Seb,
Do any of the Fn combination keys work?
I think I would reinstall the Audio Drivers and also reinstall some of the Sony Utilities.
Are you still using XP?
You can download the Original Drivers Package and the Original Utilities Package from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-N19VP_B
