Ive just upgraded from a sony vaio pcv-w1 to a vgc-lt1s, i went for this model mainly as I loved the ease of use on the W1, esp that I could watch sky tv through giga pocket as I have no external airiel and indoor ones dont work well...
Anyway ive fitted the sky airiel to the back of the LT1s but the media center wont pick it up. Please can anyone tell me if this is possible and if so how! I'm a complete newbie to vista / media center and so far hate it 😞 if someone can either tell me how it should be set up or point me to a tutoial it will be much appreciated.
thanks
In Vista Media Centre click on the top right hand VMC icon and navigate to settings using the arrows. Select TV > Set up TV Signal and follow the prompts and tick off set top box. You nay find yourself doing this quite regularly if the signal is lost in bad weather as numerous channels drop off the dial
thats what i have been doing so far & no luck... is there any other way?
thaks
