How to keep Vaio-club from starting up?
hvdkoogh
I am the owner of a VGN-TX5XN with Vista (lucky me). Starting this thing up takes forever, and then one has to wait another age for Vaio-club to start. Cannot find how to switch that of. Does anyone know how to keep Vaio-club from starting up?
Thalamus.
Champion
Hi hvdkoogh
You should be able to stop My Club Vaio.exe from starting if you go to start > All Programs > Accessories > System Tools > Task Scheduler..
In task scheduler you should have three windows, Overview of Task Scheduler, then below this Task Status and finally at the bottom Active tasks..
In task scheduler go to the bottom section of the centre column (called active tasks)
Double click LaunchMCV and in the new window select delete... :slight_smile:
See image below..
