How to make recovery discs [vgn-fz29vn]
profile.country.SI.title
pretnarm
Hello
I have FZ (vgn-fz29vn) series notebook with Windows Vista Business (notebook was suplied with Home edition).
I am able to enter VAIO Recovery Center on startup pressing F10 key.
Problem is that only four options are available:
-Windows Sytem Restore
-VAIO Hardware Diagnostics
-Restore C: Drive
-Rescue Data
Recovery partition is still installed.
Is there any way to make recovery discs?
rich912
Hi pretnarm,
To create the recovery media (from within Windows) click Start > All Programs > Vaio Recovery Center > Vaio Recovery Center.
For more detail have a look at page 16 of your user manual.
ftp://ftp.vaio-link.com/pub/Manuals/RecoTS/2007Q3_RT_EN.pdf
Rich
Go n-éirí an bóthar leat
7 REPLIES 7
rich912
Hi pretnarm,
Rich
pretnarm
Hi
Problem is that I made fresh Vista installation (not from recovery partition) and install drivers/software available on support website. Vaio Recovery Center is not available to download from support website.
Will I be able to restore original installation from Vaio partition if I use Windows Sytem Restore or Restore C: Drive?
rich912
Hi pretnarm,
In that case you will need to restore your Vaio back to factory settings using the HDD recovery utility (Restore C Drive) and then create your recovery media or order a set of recovery disks from support.
The out of warranty support number from the UK is 0905 0310006 (35p/min)
Rich
Message was edited by: rich912
pretnarm
Thanks for quick reply :slight_smile:
So if I understand correctly, using Restore C: Drive to install OS from Vaio partition will allow me creating recovery DVD/CD?
rich912
Restoring the C drive using the HDD recovery utility will restore your Vaio to ‘As Delivered’, hence you should have all drivers, utilities and software that the computer came with – including the Vaio Recovery Center.
Be aware that this procedure formats the hard drive and you will lose all personal data and third party programs. Make a backup of any personal data you may need.
Good luck and let us know how you get on...
Rich
pretnarm
Thanks again for helping :laughing:
Will report back when restoring to factory settings
rich912
Fingers crossed :wink:
