Hi, I've taken all the screws off and the front facia with the keyboard is ready to be removed but there is something holding it back. It looks like a screw
about where the position of the F6 key is.
However, there is nothing that I can see to access such a screw.
Any ideas would be appreciated.
Thank.
crb_london@yahoo.com
Hi Tony and welcome to club Vaio.
You are quoting the chassis number - I assume you have a N-Series Vaio (VGN-Nxxx), look for the correct model type on the screen surround.
If you confirm the model type is a N-Series I will send a copy of the Manual by email.
Thanks for the update and the pictures.
The Model is PCG-7T1M and my email is crb_london@yahoo.com
Thanks.
N-Series Manual sent.
I think you have a VGN-N11S.
Oops, you're right.
That's what I meant to post - sorry.
Thanks for all your help. The problem is now sorted.
That last screw was under the keyboard, so the keyboard had to be removed to access it.
Cheers.
