i have a vaio update that wont install as its older than the one i have. so how do i remove it from the update requests pls?
Hi brlocky,
does the solution offered by garczynski in the following thread help.?
yes its the same update so i will wait till sony have a fix! thanks for your help.
Did you try the solution offered by garczynski.?
reinstalling Vaio Update and Vaio Care fixed the problem with Vaio Care,
he still has the same problem as me, that is:- VAIO Peripherals Metadata 1.0.1.12090 update. I cannot install it, both automatically through Vaio Update and manually. Installator says that a newer version is installed already. this is what sony will hopefully put right.
Ok, hopefully a fix will appear soon, I know Sony have been made aware of the problem..
