How to remove "My Club Vaio" from startup
lisa.cleverley
I have the solution to this :slight_smile:
Navigate to C:\ProgramData\Sony\MyClubVAIO\MyClubVAIO.exe and delete the offending programme. Then delete the folder if you wish.
There is also a shortcut in C:\Program Files\Sony\MyClubVAIO which you may delete to remove traces.
Hope this helps everyone get rid of the annoyance.
Lisa
Thalamus.
Champion
Thanks Lisa,
Alternatively you should be able to stop My Club Vaio.exe from starting if you go to start > All Programs > Accessories > System Tools > Scheduled Tasks..
Then dis enable the MCV entry..
Or
Depending on your Vaio model Sony has also recently released a Startup fix for My Club VAIO, check out the download section for your Vaio here.
kee-lo_
Haha thanks for that Lisa, I agree, it's a PITA.
Like your website btw
