HOW TO REMOVE RECOVERY PARTITION?
George.m
Hi
I want to remove the recovery partition to have more disk space.i have wrote the recovey disk's and now the recovery partition is useless. :thinking:
7 REPLIES 7
huntuibui
Hi
You should be use the Partition Magic 8 software. I removed the recovery partition by it and now I total have 80GB "fresh space". You'd better create 2 recovery DVD before you remove the Recovery Partition .
If you don't have Partition Magic 8 software. Please contact me. I'll send it to you
My e-mail: huntuibui@yahoo.com.
Regard!
Thalamus.
Champion
Hi George.m,
Back up all important data and create at least two recovery disc sets before you remove your Recovery Partition. Then make sure you recover your Vaio using the Recovery Discs that you have created, this will ensure that the disc's work correctly.. :wink:
Here is Sony's guide on removing the recovery partition..
George.m
Thanks thalamus and huntuibui
But i will lose any data? :thinking:
ps:sorry for my english
:smileygrin: Mery chrsitmas to everyone :smileygrin:
Thalamus.
Champion
Hi George.m,
If you use a third party program such as partition manager your data should remain intact, however, should you need to recovery your vaio in the future and discover that the Recovery Disc's you have created do not work then you would need to purchase set from Vaio-Link (approximately €112) :slight_frown:
kee-lo_
ALWAYS back up when playing with Partitions, it can go sour!
George.m
Thanks for the advise.I will waiting for a recovery then to test my recovery disks :wink:
______________________________________________
:smileygrin: Mery christmas to everyone :smileygrin:
Thalamus.
Champion
:cool: You're welcome, good luck.. :four_leaf_clover:
