I want to use rewritable DVDs on my SZ1XP with Matshita UJ-832D drive, but can't see how to do it. Do I need to buy third party software (suggestions?) or is there somthing under the Vaio menu that will do it? BTW I just want to read and write files, not create videos with singing and dancing menus.
Thanks in advance for any help.
Hi Good Music
Your Vaio SZ1XP should have Roxio DigitalMedia SE 7 pre-installed, if so this program would allow you to burn DVD-RW disc's.
Much appreciate your help Thalamus, thank-you.
Some of Roxio was there. I uninstalled and re-installed and it works.
For anyone reading this in the future, you can burn, erase and re-burn a DVD-RW in its entirity with the pre-installed version of Roxio, but you cannot add or delete individual files without erasing the whole DVD. There is a $70 upgrade to give full r/w capability.
You're welcome Good Music, glad it worked..
