As says in the title where is it on the mainboard of the computer
Solved! Go to Solution.
It would seem that your model doesn’t have this feature.
Have a look at your user guide to make sure.
http://www.sony.co.uk/support/en/product/vpcca2c5e
Rich
Hi Lilyesque,
I'm unsure of the exact location on your model, but it is often just to the left of the keypad. If you run a paper clip along the top of the screen surround you will locate the actuating magnet and the switch itself will be in the corresponding position when the lid is closed.
Rich
Hi thanks for such a quick reply, I was looking into how to switch off the screen without switching off anything else. It indicates on this page http://www.sony.co.uk/product/vn-c-series/tab/editorialarticle1 under the 'lifestyle' tab under the 'backlit keyboard' heading that this is possible. I am assuming you are meaning the mechanism when I close the lid.
I misunderstood your question.
If your model has this feature you should find the ‘Display Off’ button next to the ‘Assist’ button.
Rich
Next to my Assist button is a Web button. My model is pcg-61713m
sorry vpcca2c5e is it
Rich
Many thanks
