i cant find vaio update 5 on my vaio
vaiodave
i dont seem to be able to find udate 5 file vaio update is there but not 5 it is mentioned in the manual and a was wondering why its not there
Thalamus.
Champion
Hi vaiodave,
What Vaio do you have.?
Vaio Update 5 should be found on the right of your task bar next to the clock in the system tray. If you can not see it try pressing on the arrow to the left f the system tray as this should display more icons.
If you are still not able to locate Vaio Update then try looking at the icons on the top of Start > All Programs list..
vaiodave
i do have a vaio update just not vaio 5 update that is mentioned in the manual my model is the vpcec3soe thanks for the help
