I dont want my built in mic!
jpoa
Hi there everyone!
Ive purchased a quite expensive set of headphones with a built-in mic and i want ti use them instead of the bult-in mic of my vaio! It is a fj1s/w, i just dont know how to do that! There is only one input device available, although i can record with the mic plugged in the jack, but there is some sort of feedback (two mics recording... :S )
Help!
profile.country.de_DE.title
seb21__
You can select the Sound Record Device there.....
HTH
