Hi everyone,
I was hoping that someone might be able to help me with my Wireless issue.
Any help people can provide would be much appreciated.
Thanks very much,
Message was edited by: Elmo265
Hi Elmo,
Please check the following: -
1. Is the physical sliding wireless switch on the front of your computer in the 'ON' position?
2. Is the software wireless switch turned on in VAIO Smart Network? Double-click on the small green/blue square in the system tray (bottom right of screen) and check that the box next to 2.4GHz Wireless Lan is set to 'ON'.
Once i double clicked on it a few times it seemed to kick back in to action.
Thanks very much Blencogo!
