I have lost the recovery discs for my Sony Vaio VGN-AR41L. Where can I get replacements?
IanGamse
Tags (1)
Thalamus.
Champion
Hi IanGamse,
welcome to Questions & Answers..:smileyhappy:
Your Vaio should have a hidden HDD recovery partition so you should be able to restore the Sony  supplied operating system and the pre-installed applications by doing the following.
Start your Vaio and when you see the Vaio logo press the F10  key repeatedly, hopefully this should start the recovery process using  the hidden HDD recovery partition.
Then follow the recovery instructions to complete the process
If the F10 option does not work then you can contact Vaio support and purchase a set of recovery disc's for your vaio..
You  can find the contact details for vaio support by either clicking   Support at the top of this page or by using the following link:Vaio support
Under  Log-in option 1: enter your VAIO's serial number
Then click Log-In
Once logged select Get In Touch..
