i need a bios password for VGN-FJ180P
fontibila
i have a VGN-FJ180P notbook. my soon puts i bios password and hi don't know the bios password. i need to reset the bios password.
the key for ontime password is:
K2FV-76V6-9D3J-PH9H
can you help me
rich912
Hi fontibila,
You will need to contact support to obtain a code. You will find the procedure under option 1 in this link. Type 'reset forgotten bios password' in the search field.
http://www.sony.co.uk/support/en/product/VGN-NR38E_S/tips-and-solutions
Rich
Message was edited by: rich912
Go n-éirí an bóthar leat
rich912
Hi fontibila,
Rich
