Hello,
sorry for my english but my problem is that i cannot delete the Vaio Recovery Partition Eisa .
I ask Mr. David Hen.... from Vaio Hotline and he said that i need a special program.
Have someone an idea to delete the vaio recovery Partition without new porgrams on it.
I made recovery Disk and dont neeed the partition right now.
this had frustrated me in trying to find a solution for you!
It looks like a program called Acronis True Image will do the trick for you but i cannot guarantee this
google it and check it out i guess
Hi mgrasek100,
The Sony way is to use the Vaio recovery tool and at no 10 select C & D Recovery (Change Partition size)..
However all the data on your hard drive(s) will be removed and then your Vaio will be recovered back to the factory settings..
The other option is to use a third party program something like Paragon partition managerwhich should allow you to resize partitions without data loss...
Which ever way use choose it's important to back up all important data first..
