Increase RAM Problem on pgc-k215m
Mali_HR
Hi guys,
i'm owner of a pgc-k215m and i will increase the quantity of RAM.
It's original RAM configuration is 2x256MB RAM. The RAM is a 256MB PC2700 CL2.5 from Infineon.
It support Max 1024MB of RAM.
The problem it's that when i insert a 512MB PC2700 CL2.5 from Apacer the notebook see only 256MB. I had make an attempt with a 512MB PC2100 CL2 but the result is the same.
Someone can tell me which is the problem or better give me a solution
THX
0 REPLIES 0
