Indicator light has been on 4ever!
Vivi4eveR
Hi,All.
I've got seriers FZ11L at the moment. The problems is the Lock with 1 inside indicator light [upon Prt Sc button] has been on since this afternoon,even I shut the laptop. I've tried to unplug the AC adaptor and the light would went off but once I plug it back,The light is on. Other buttons work alright .I've tried to press Num LK key as well...the light is still on. How can I solve this problem?
Thank you
Thalamus.
Champion
Hi Vivi4eveR,
the lock with the 1 inside indicates that number lock is enabled, press the Num Lk key once and the light should go out.. :wink:
Vivi4eveR
Hi Thalamus
The problem has been solved..although I had tried to press Num Lk button without any effect. I unplugged the AC adoptor for the whole night and today I switch on the laptop and whola.....the light has gone...lol
Thank You Very Much.
Thalamus.
Champion
You're welcome, I'm glad the problem is solved.. :slight_smile:
