the a317m comes with XP home (SP2) ...personally i prefer like to install XP pro (multi-language pack) with SP1. other than puting the XP cd and upgrading. is there there anything else that needs doing before or after the upgrade.
also the software bundle from vaio (incl. adobe), can it be incorporated in to XP pro.
Sony don't support updating the OS very well
had you burn a copies of the recovery dvd?:smileyconfused:
