I installed VAIO Zone 1.2 Upgrade Program following which my TV has disappeared. When I either click TV on VAIO launcher or the "Live TV" button on the remote control the media options don't list TV (now only music, pictures, movies, CD/DVD).
Using vgc-v2s.
Any ideads ?
George King
I'm not too sure what the upgrade was supposed to fix but it sounds like it's caused more problems than fixes.
If there was nothing wrong with your Vaio Zone before why not use your Windows Restore to roll back to a point before you installed the update.
If it ain't broke it don't need fixing!
Good Idea, never thought of that...
GK
I had the same problem after doing this upgrade. Solution to fix... I restored the V2S with the recovery tool.
After i tried the upgrade and now it works
