Hi. I run Windows XP Proffesional SP3, and I am attempting to follow instructions to install a video driver. The instructions come from the Sony website and are these:
1. Download the video driver ( VCD_Nvd_4690.zip ) and save it to a download directory
2. Right-click the Zip file and select Extract All
3. Follow the on-screen instructions to extract the Zip file to a directory (please note this folder for reference)
4. Close all running programs.
5. Open C:\Drivers and rename or delete the "Video" folder
6. Click Start, click Control Panel, and then click the "Add or Remove Programs" icon
7. Select "NVIDIA Windows 2000/XP Display Drivers" and click "Change/Remove"
8. Click Yes, and then Click OK to restart the computer
9. After computer restarts, a Found New Hardware Wizard appears automatically.
However from step 5 onwards none of it is possible. The Drivers/Video/NVidia folder is not there, Nvidia doesnt show up under add or remove programs, and I never have a Found New Hardware Wizard appear. I have checked in device manager and no Video/Display Adapters show under it.
Please help
Solved! Go to Solution.
Hi ItsAaron,
I’m surprised that you can find nothing listed in Device Manager under Display Adaptors or at least an adaptor with a warning that drivers are not installed. If an adaptor of some description was present you could update the driver using the ‘Have Disk’ method:
If all else fails then try installing from the INF file contained within the download package. Extract VCD_Nvd_4690.zip to a known location – such as a new folder on the desktop. Then, within that folder, locate NVSZ.INF, right click and select ‘Install’.
Rich
Hi ItsAaron,
Rich
