Hi all, I've the following problem.
- I own a Sony Vaio VGN-SR21M and an Internet USB key Huawei E169.
- I used successfully the key until yesterday.
- Now the key is no more recognized when I plug it into the USB slot: no modem and no removable disk appear (the key has also a flash disk).
- The key is powered, because the led light is on and flashes as usual.
- The key is fully working when moved to another PC.
Someone experienced the same problem, or a similar one involving USB devices?
Thanks in advance,
Umberto
