InterVideo WinDVD for Vaio won't work anymore
mike9586
When I first got my Vaio, the included InterVideo WinDVD worked great when I played DVDs but I came to play a DVD today and it just wouldn't work, I clicked on the icon, I got the spinning "working" wheel for a few seconds then that was it, nothing happened. I tried restarting my computer but still nothing.
I do know there was an update to it a few weeks ago via the Vaio Update site but I haven't used it since until now.
Can anyone help?
5 REPLIES 5
97122769
Can anyone help?
If your only watching DVD's then you can use Windows media player instead. to be honest WinDVD is really aweful, it stopped working for me after a while as well.
Alternatively, you can download VLC player for free, which will play almost anything you throw at it including DVD's. Link is here http://www.videolan.org/vlc/
mike9586
I do have VLC and it does play most DVDs but this DVD was a DVD+RW that had been recorded in a DVD Recorder and it just crashed VLC for some reason.
pythos
After the update of WinDVD and you run AVG you have a horse trojan but it is a "false positif" . With a neuw update of AVG your WinDVD will be OK
mike9586
It's all working now.
I didn't think AVG had found anything wrong with any of the files until I was doing a virus scan today and went into the "Virus Vault", two files from the InterVideo folder were in there, I restored them both and it's working fine now.
Plus AVG doesn't consider them a virus any more.
arda1971
Use Kaspersky fellas!
