Can anybody tell me how to get the IP address for my SONY VAIO VGN-FW11E. Is this individual to my laptop or is it the same for all of the same model. I have tried going to command prompt and releasing it etc as per the sony help but this doesnt work. My ISP says to ring sony and ask for it, but theyre only onpen monday to friday 8-6 so I'm without internet till they get back to my email.
If the IP address is the same for all VGN-FW11E please can someone with the same mode please access their IP address and send me it?
Luis is right. Let us know what is displayed when you go to the CMD screen and type in IPCONFIG /ALL?
If your Router is set to be a DHCP Server and your Vaio is set to 'Use DHCP' it should connect.
What ISP are you using?
What make and model router are you using?
What wireless security have you set up on the router?
