Is it normal?
TerryChou
Is it normal?
I have bought a vaio VGN S2XP notebook for several days, I found my notebook's battery just can max stay in about 3 hours,but the instructions says it should be 3 hours and 40 minutes. Is mine too short? Is it normal?
Vas
It depends on the ussage.
ant1uk
3 hours is very good, they give the max time with the lowest usage settings 3 hours is better than normal nothing to worry about
blue1901
3 h is great man! some people said 1.30 hours! but it will reach 3.40 h with total discharge and recharge for several days.
