is it possible to get sound from home cinema than tv
druggy21
i was wondering if someone could help me out.Its not a problem or some sort.Thing is my vaio allows to play blu ray discs and connecting the laptop to hdtv via hdmi..that works wonders and theres sound too.but i was wondering,is it a possibility in getting the sound out from my home cinema instead of the tv and if so..how can i go about doing it?..
drali
You need to configure your tv with your home cinema system.
1. First turn everything off and disconnect the plug physically and reconnect and turn on
2. make sure your tv is connected to your home cinema system (2nd hdmi from tv)
3. change tv audio output to the home cinema system
4. configure home cinema and make sure it works
5. connect vaio to tv and make sure hdmi connection is enabled and sound options via control panel are set to hdmi
