:smileygrin: how do i play my songs from my vgf ap1l on other music systems ?
Use a cable connector with stereo out mini plug to line out on the cradle of the vgf ap1l other end should be a 2 end phono jack usually red and white which would normally connect to auxillary in on your hifi. Select aux input on your hifi annd play on your sony.
The only critical factor is the correct lead and having some sort of input on your hifi
Maplin Elctronics sell the lead for £2.99 part number L32BA
I think you can use the line out and then go in our HIFI in a free place. I hope you understand I#m form Germany!:smileyhappy:
what i do in my bedroom is have some old computer speakers. the jack is just the same and it works fine!
