I found from the A397Xp specifications which said that there is a bluetooth built inside of this laptop. However, I try to connect my mobilephone, it can not find my mobilephone and my mobilephone can not find my computer as well. In control panel,in the bluetooth device hardware and device, there is nothing. Could you tell me is there a Bluetooth built inside of this laptop and how can I connect my mobiephone.
BTW, I have already installed my mobilephone handset manager, it also can not find my mobilephone.
did you see a little green icon written LAN located at the lower right hand side by the time/date? double click it and you get the wireless device switch window, then select/tick the bluetooth.
Have you selected the check box `Allow other devices to connect to this computer¿ in the Options Tab in the BlueTooth Device dialog?
