itunes and media buttons on ar11m
mex23
Hi guys, I have a question for you!
How can I configure the buttons: next, previous, pause near the keybord for iTunes or other player?
Thanks in advice :slight_smile:
5 REPLIES 5
Twisted-Rizla
Hi
Welcome to the forum
I'm not 100% sure with your machine but do you have a small silver looking button with an 'S' on it? (Should be on your lower right hand task manager) If so just right click it and you can reasign any program to open when you hit the short cut button.
kee-lo_
I don't think they work with iTunes, it's mainly specifically for SonicStage (boo)
Twisted-Rizla
Typical!
mex23
ok, anyway thanks!
mex23
I don't know why, but now the buttons works with iTunes! well 🙂
