iTunes library transfer?
profile.country.en_IE.title
Aine-Marie
What would be the best way to get iTunes library from home computer onto laptop? Would buying an external memory thing be the best thing to do? iTunes library has about 8 GB on it. Any suggestions? Thanks!
Áine
Drumzman
Hello Aine,
An external hard drive would probably be simplest, unless you have a memory card with more than 8Gb capacity.  A couple of recordable DVD discs would also be enough as an alternative.
I found this website helpful:
http://ipod.about.com/od/transferituneslibrary/ht/transfer-itunes-new-computer.htm
Good luck!
Mikey_
No need for any hardware if you have a network.  Just turn on share music library on the desktop, it should then appear in iTunes on the laptop, and you can select what you want and click import.
