SOME CARACTERS ARE NOT CORRESPONDING AS THEY ARE MENTIONED ON THE KEYBOARD.
FOR EXAMPLE + = } GIVES THE RESULTS - _
I HAVE CHANGED ALREADY THE COUNTRY SETTING BUT WITHOUTH RESULT. WHAT TO DO ???
Hi Pompom and welcome to the forum.
The key layout that you describe would seem to be French/Belgium but the country settings producing - _ would be English or similar. Where did your notebook originate from and which country settings are you using?
i bougth this notebook in belgium (flemisch) but the keyboard is french. i changed the settings to french keyboard but countrry belgium and problems are solved. thanks very much for your information :smileygrin: :smileyblush:
No problem, I am please to hear that the keyboard is now functioning as it should:smileyhappy:
