Keys Fn+F1-12 don't work
SirCaledor
Hi everyone,
I just got a Vaio FS515E and I'm incredibly happy with it!
One thing is weird though: The Fn-key doesn't seem to work which means that I can't access the brightness, speaker volume, or even sleep mode on my keypad. Does anyone have an idea what that could be? All the region-options are set correctly.
Thanks for your help!
Best,
Oliver
Hi Oliver and welcome to Club Vaio.
You need to reinstall some of the Sony Utilities.
If you have a directory C:\Utils then double-click on Utils.exe to run the installer.
If you don't have this directory, download the Preinstalled Sony Utilities from VAIO-LINK, unpack the download to a temporary folder and install
1 Sony Utilities (installer folder 1)
2 Sony Shared Library (installer folder 2)
3 Vaio Event Service (installer folder ?)
And then re-boot your Vaio - you may have to repeat the process!
:wink:
SirCaledor
Hi Blencogo,
Thanks a lot for the quick reply. I did as you suggested and now everything works fine. My vaio experience is complete! :grin:
Best,
Oliver
