just a general question...does anyone know how long a laptop battery last for without having its power adaptor attached to the laptop whilst working? its just that mine dies after 10 minutes and i always have to have the power adaptor on so that my laptop wont just shut down.
Welcome to ClubVaio Nessystar,
To give you the appropriated answer, tell us your laptop model...
hello....my laptop is vgn fz11z
After some research on internet (google), I am afraid to say that this time (10 minutes) based on comments over the internet by others FZ 11Z owners is correct.
I would like to suggest for you to buy a new battery 'cause I found several references saying that the second battery work very well.
You can found good price options here.
Did you get a new battery? Will you let us know if it improves things?
My FZ21Z has an appalling battery life, its the only thing I regret not checking when I purchased . It's a bit better under windows 7 but I get twenty five minutes at most now!
...You can found good price options here...
If you check, they have every Sony laptop battery in stock apparently!
BEWARE
BEWARE
