- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
After trying to load AVAST onto a W7 system, my laptop has frozen and so far, I've not found a way of resetting using the 'normal' controls (e.g. power off - doesn't do anything). I suspect I will need to do a hard reset, but can't see any rest hole or facility. Can someone help?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi SENIOR71,
There are very few notebooks that now have a CMOS reset button. From memory the last one I had was approx. 10 years ago.
Try removing the power adaptor and battery and then hold the power button down for 30 seconds. Reattach the battery and power adaptor and try rebooting.
Rich
Message was edited by: rich912
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi SENIOR71,
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Rich,
Many thanks for your advice - it worked & the laptop is now back in operation. I wonder why manufacturers decided to dispense with the 'easy' solution?.
SENIOR71
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Good to hear the machine is up and running again:smileyhappy:
The "easy solution" adds manufacturing cost.....:smileywink:
Rich
