Hi all,
My VGN-N38Z/W has no s-video. Can I coonect the laptop with the vga output to TV?
The cable VGA to Scart exist, but can a normal TV handle this signal?
gr.
Hi JoppeN and welcome to Club Vaio.
The VGA output is not compatible with most TVs unless they have a monitor connection.
You will need something like this converter to do the job!
http://buy.maplin.co.uk/Free_UK_Delivery/PC_to_TV_Convertor_35258/PC_to_TV_Convertor_35258.htm
This gives a S-Video and Composite Video output which can be connected to a scart adapter.
Hi Blencogo,
Thank you for your answer.
this cable doesn't work?
http://www.pixmania.com/pt/pt/168229/art/hama/adaptador-vga-femea-scart.html
Do I need a converter?
gr
I do not think it will work without a converter box but at that price you can always try it.
I cannot Google in Portugeese - Try 'VGA to TV Converter' and see what you get.
I think you will need something like this box: -
http://www.amazon.co.uk/Kworld-PC-TV-Converter-USB/dp/B000FIEIMS/ref=pd_bbs_1/203-9309403-5511913?ie...
