laptop user manual sve
uselesser
can anyone please provide a link to download user manual for sve1712z1eb laptop?
rich912
You should be able to extract the downloaded Zip file by right clicking and select ‘Extract to..’ – select the location and click OK. Open the extracted folder, ‘aeca100111’, expand the ‘eng’ folder and double click ‘index.html’.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
uselesser
Thank you.  However I was hoping for an unzipped link.  Or a means of unzipping the version provided.
rich912
Rich
uselesser
I appreciate your helpful guidance. I now have the manual on my 'favourites'.  Many thanks.
rich912
You're welome :slight_smile:
