LCD Monitor damaged (Pixel Errors)
WHIP
Hi to all,
I must say that I am very sad about his issue :slight_frown:
I have a Vaio VGN FE21H, that is about 7 Months old, and since one week I've noticed that the pixels of my display are going dead 😞 Its not a single pixel that stays white, but many pixels around the screen. They are not completley white, but when u look at the screen with a gray background you see mazes just like clouds around the screen. Most of them are in the Top and the bottom of the screen. Looks something like if u have water that came insade of the lCD 😞
Its looks like the Reaction time of the pixels is somehow dead.
Some times i even get a complete white line at teh top of the panel. Thats the line witch is actually under the address bar of any window. When i minimize it, it just stays there, and fades out after 10 or 20 mins.
Same thing with the other areas.
DOES ANYONE HAVE OR HAD THE SAME PROBLEM?
This cant be true, its still a brand new baby, and I treat it like one 😞 😞 😞
Thalamus.
Champion
Hi WHIP,
I suggest you open a case with Vaio-link ... :slight_frown:
WHIP
HI Thalamus,
Yes I will do that, have no choice. Just wanted to know if someone had the same problem.
PS: when i open a fullscreen Gray image, i can steel read the "START" string on the screen...
