I am the owner of a Vaio
RA104 and up till now I am not able to record via the line in on both front and back of the PC. It only works when I make use of Giga Pocket's Video rear or front option turned on.
I am using CoolEdit 2000 to record and I have really tried everything as far as I know.
Can someone help me ?
Strange.
Did you install all the RealTek utilities from the DVD?
Strange.
When you plug in the line source does a popup apear asking you the source of the line?
Yeah reinstall the realtek software.
Make a System Restore Point under Windows XP, so you can at least turn back the clock if your computer doesn't work as expected.
Also remember you have the Driver Rollback feature in Windows XP too.
.....or to delete the soundcard and let it be found again by Windows ?
Yeah I agree with Rich, uninstall the card and try rebooting.
