LM2E XP-pro install cannot find hard drive
DerekBurleigh
When I try and install Windows XP Pro on my LM2E VAIO the install tells me that it cannot identify a hard drive on my computer.
If I press F6 during the install to install a 3rd party disk driver it then tells me I can´t because the PC does not have a floppy drive!!
Obviously the hard drive is there!!
How do I get round this problem?
Hi Derek and welcome to Club Vaio.
You either buy a cheap USB floppy drive for a few pounds and install the SATA drivers from this floppy using F6 or you make a slipstreamed installation disc using nLite where all the drivers are slipstreamed into the XP installation.
Google for nLite
:wink:
DerekBurleigh
Hmmm.....
Slipstreamed the disk controller drivers into the XP install but it still doesn´t work.
I will see if I can work out what I have done wrong!! :slight_frown:
Which SATA drivers are you using?
It should be SATA Driver Intel Non-RAID 7.0A-7.0.0.1020
It is attached below: -
