hello i want to overclocking my vaio and want a bios update but i dint find it .can me somebody help to get one?
I'm not sure what you've been told about overclocking but a BIOS update won't allow it (not on a Vaio anyway) and since you have a laptop overclocking is an exceptionally bad idea. You will almost certainly overheat your computer and damage it, which isn't covered by the warranty.
Don't do it. At all.
TT's right, avoid doing this
www.vaio-link.com downloads section. It doesn't allow you to overclock and it doesn't change anything in the BIOS either. It's just for improved compatibility. I really recommend you don't do it.
