Looking for a replacement fan Sony Vaio VGN-CS21S
profile.country.sv_SE.title
mryb79
Hi Sony.
I am looking for a replacement fan for my girlfriend's Sony Vaio VGN-CS21S as it's been making churning noises for the past two years.
She's been too lazy using other computers in the meanwhile, and I finally have some time over to fix it.
Does Sony sell replacement parts?
Thalamus.
Champion
Hi mryb79,
welcome to Questions & Answers..:smileyhappy:
There  have been quite a few posts on the forum regarding the fan  noise on  some CS series Vaio's and Sony also released a statement  regarding the  CS series fans. See below...
https://www.sony.co.uk/discussions/servlet/JiveServlet/downloadImage/2-613080-1728/450-147/Fan+statement.jpg
Therefore I suggest you contact Sony Vaio support you can do this either by   clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: enter your VAIO serial number
Then click Log-In
Once logged select Get In Touch..
10 REPLIES 10
rich912
Sony doesn’t supply only parts but there is the possibility that one of their service partners may be able to help.
http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGN-C2S_P
Otherwise try the following link:
http://www.batterymall.co.uk/sony-vgn-cs21sv-fan-p-184594.html
You may possibly find that the existing fan just needs a thorough clean so I suggest that you check this out before parting with your money.
Go n-éirí an bóthar leat
Thalamus.
Champion
Hi mryb79,
Then click Log-In
mryb79
Thanks Rich912. I'll look into it.
mryb79
Thanks for the tip Thalamus.
By the way... That there replacement for free. Is that the one where they come get your computer, erase the s*** out of it and ship it back after two weeks with a new part?
Thalamus.
Champion
It states in the statement above...
Sony will cover the cost of the repair during the first four years following the date of purchase of the model in question..
As to the turn around it's normally arond about five days..
As to your S*** I can't see why anyone would want to touch it..:smileyconfused:
mryb79
I know Thalamus. But someone told me once that Sony erased the whole thing no matter what when it's a hardware issue. I was wondering if the technicians still do that.
Thalamus.
Champion
It may be worth mentioning that when you contact Vaio support..
However to be on the safe side it may be worth backing up important data before sending..:smileywink:
mryb79
Well my gf can't find her receipt so it's up to me now. Upon taking the thing apart I realized the sound was indeed coming from the fan going plastic-on-plastic. Sony must have gotten the raw end of the deal when the factory decided to put that particular fan in. :dizzy:
Oh well. We live to fight another day. At least we got three other computers to use for the time being.
Thalamus.
Champion
If your gf registered her Vaio then she may still be able to get a repair, have you tried contacting vaio support..:smileyconfused:
