I have lost my mass storage drivers and cannot work out which of the driver downloads, on the Sony restore site contains these. I have a Sony VGN-NR38E. Can anyone help please?
Solved! Go to Solution.
This will be the Memory Card device and you need to install the Memory Card Reader Writer Driver which was originally installed. You can download it here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-NR38E_S
Once I had worked out how to run the download, it worked perfectly. Thanks for the help.
